I tried to run a simulation in OpenStudio, however there is a fatal error because of the IDF file. When I tried to export the IDF file directly from Sketchup in order to resolve the problem, I encountered the following warnings: Warnings occurred on translation to EnergyPlus Warning: OS_ProgramControl is not currently translated
I also tried to import the IDF file to OS but I received the following message: C:\fakepath\fatal error.JPG
How can I solve this problem? Thanks
