how to define two connected set points for cooling without heating in energy plus?
I want to create a zone ventilation with a fan coil in a small zone which does not have any openings on its surfaces.
When the temperature of zone reaches to
28 degrees centigrade 28°C the fan turns on and continues to do the cooling to
24 degrees. 24°C.
Then, at
24 degrees 24°C it turns off; and will turn on again when the
temprature temperature reaches to
28 degree. 28°C. Accordingly this cycle happens repeatedly everyday. We use thermostat in energy plus modeling but the problem is that it does not have two set points for "on" and "off" in cooling. So my question is how can I
do so in energy plus?
