Hello.
Two questions for VRF "models 2" (VRF-FluidCtrl).
1. Is it possible to introduce my own curve of evaporation temperatura for refrigerant?.
2. Does the algorithm for indoor unit calculates the cooling coil sensible based on the evaporation temperature of the refrigerant?. It is said, while higher temperature of evaporation greater relation sensible/total.
Thank you very much.
