Hello.
I have idf file which implement series of chillers setting Minimum Part Load Ratio 0.2.
However, looking at result, it seems that chiller is being operated below Part Load Ratio as pointed out by red line in below histogram graph. (visualized data excluded the case part load ratio = 0)
Does anyone know why chiller operate below minimum Part Load Ratio and teach me how to avoid this operation?
Thank you!
