I used the template generator to import 90.1 2010 /2007 construction set for weather zone 3. However, the severe errors show as follows. Any reasons why the template construction is wrong ?
** Severe ** Out of range value Numeric Field#4 (Specific Heat), value=0.23885, range={>=100}, in MATERIAL=CEMENT BONDED PARTICLE BOARD
** Severe ** Out of range value Numeric Field#4 (Specific Heat), value=0.38215, range={>=100}, in MATERIAL=CHIPBOARD FLOORING
** Severe ** Out of range value Numeric Field#4 (Specific Heat), value=0.23885, range={>=100}, in MATERIAL=CONCRETE DECK
** Severe ** Out of range value Numeric Field#4 (Specific Heat), value=0.24601, range={>=100}, in MATERIAL=INSULATION
* Severe * Out of range value Numeric Field#4 (Specific Heat), value=0.23885, range={>=100}, in MATERIAL=MEMBRANE * Severe * Out of range value Numeric Field#4 (Specific Heat), value=0.23885, range={>=100}, in MATERIAL=PLASTERBOARD * Severe * Out of range value Numeric Field#4 (Specific Heat), value=0.10748, range={>=100}, in MATERIAL=RAINSCREEN * Severe * Out of range value Numeric Field#4 (Specific Heat), value=0.23885, range={>=100}, in MATERIAL=REINFORCED CONCRETE
