What is the difference between Fan Coil Total Cooling Rate and Cooling Coil Total Cooling Rate? I put ZoneHVAC:FourPipeFanCoil in a zone,and i found huge difference between Fan Coil Total Cooling Rate and Cooling Coil Total Cooling Rate, the Cooling Coil Total Cooling Rate is much larger than Fan Coil Total Cooling Rate, why?
