hi everyone, i'm new with openstudio and i have a question. i'm trying to simulate a mixing air between two thermal zone. I have two rooms 3x3x3 (thermal zones) and between these rooms there is an air wall for the mixing. in room A i have the fancoil and temperature set on 23° C, in the second room B there isn't the fancoil becouse it receives fresh air from the room A. when i run the simulation i have two different temperatures: in room A 23°C, in room B 38°C. Then i used the BCL measurement "air wall mixing" but the temperature in room B decreases to 34°C. But I think this is not correct. Do you have any suggestions? thank you very mutch
