As the question title states, I would like every measure which I use to be in SI units.
I noticed that most measures are taking ip units as inputs - however I also noticed that in several measures that these ip units are converted into si within the code of the measure itself, is this the case with all measures created by NREL?
What would I need to do to convert every measure to SI units, are the underlying helper functions in ip or si?
Furthermore will OpenStudio server work with every measure using SI?
