I am writing a test for my own reporting measure, the measure works fine when I run it in the OpenStudio app however when I try to run it with my test it test says No workflow provided, using empty WorkflowJSON.
For this reason my measure fails when it gets to the line of code: (I am trying to get the name of the osm which the measure is being applied to know)
currentModelName = runner.workflow.seedFile.get.to_s[3..-1]
Since in this test I am not actually running the osm model I simply want to test the reporting measure, how can I load the workflow in the test without actually running the osm model?
