When entering VRF inputs in an OpenStudio model, there are equivalent length inputs used to estimate piping losses.
Does the "Equivalent Piping Length in Cooling Mode" represent the length of the farthest terminal unit from the outdoor unit and should this typically be equal to the "Equivalent Piping Length use for Piping Correction Factor in Heating Mode"?
The Engineering Reference documentation gives a definition of the equivalent length in the heating mode section; I didn't see it in the cooling mode section but I'm assuming it's meant to represent the same thing (i.e., piping length to the farthest terminal unit).
