Alright, I have used GLHEPro for years to design well fields for my company so I am knowledgeable in its uses and application. Previous workflow included using eQuest but this is my first time trying to use the measures in E+.
Sizing is not a problem as the results seem to align with my experience in well fields but bringing the G-Function back is not working at all. I get an immediate notification while applying the GLHEProGFunctionImport measure that there are missing fields. Then when I apply changes and review the well field I notice that some of the data is in the wrong fields.
I am attaching a copy of the measure warnings and a screen shot of the openstudio loop. Also, I am including a copy of the G-Function export from GLHEPro. The error starts at the ground temperature and continues on.
I am not sure if this is a software version issue but I am up to date on everything including the latest version of GLHEPRO.
Any thoughts? Even if I open up the GLHEPro output and manually enter the data something is just not right.
