I am having a very strange issue with OpenStudio server regarding a measure which previously worked.
I recently changed our OpenStudio spreadsheet and added a few more SQL querys to the measure - I tested the measure and it works fine locally.
Now when I try to run the spreadsheet, the osms and the measure on the OpenStudio server we get the following issue seen in the png attached.
I am at a loss to understand why, I am also not sure what I should be attaching here to help you guys debug this with me.
Does anyone have any pointers on what is going wrong or do you need more information? If the latter is the case what additional information do you need?
Many thanks
