Hello, I am a new user of Openstudio and wish to use the Radiance daylight measure. I'm using Sketchup 2017 and openstudio 2.2.0 After reading the Installation and Introductory Tutorial, and wachting tutorial videos I created a simple model to try but when I ran the simulation I got an error message about not finding a file or directory. It may be very simple but I really don't know why I had this error. Is it a problem of version ?
Does someone have an idea where the problem comes from ?
The error message is :
*Initializing workflow.
Processing OpenStudio Measures.
Applying RadianceMeasure
Result: Fail
Error: No such file or directory @ rb_sysopen - C:/Users/julie/AppData/Local/Temp/OpenStudioApp.yW6368/resources/run/000_RadianceMeasure/radiance/options/treg.opt
C:/Users/julie/AppData/Local/Temp/OpenStudioApp.yW6368/resources/measures/RadianceMeasure/measure.rb:714:in initialize'
C:/Users/julie/AppData/Local/Temp/OpenStudioApp.yW6368/resources/measures/RadianceMeasure/measure.rb:714:inopen'
C:/Users/julie/AppData/Local/Temp/OpenStudioApp.yW6368/resources/measures/RadianceMeasure/measure.rb:714:in run'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/util/measure.rb:450:inapply_measure'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/util/measure.rb:74:in block in apply_measures'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/util/measure.rb:32:ineach_index'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/util/measure.rb:32:in apply_measures'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/jobs/run_os_measures.rb:52:inperform'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/run.rb:261:in step'
:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/run.rb:210:inrun'
:/openstudio_cli.rb:804:in execute'
:/openstudio_cli.rb:620:inexecute'
:/openstudio_cli.rb:1517:in <main>'
eval:85:ineval'
eval:85:in require_embedded_absolute'
eval:70:inblock in require'
eval:64:in each'
eval:64:inrequire'
eval:2:in `<main>'
Info: Radiance multiprocessing features are not supported on Windows.
Info: Using 1 core(s) for Radiance jobs
Info: Running in debug mode
Info: Found Radiance at: C:\openstudio-2.2.0\bin..\Radiance
Info: Found Perl at: C:\openstudio-2.2.0\bin..\Perl\perl\bin
Info: Found EnergyPlus at: C:\openstudio-2.2.0\bin..\EnergyPlus\energyplus.exe
Info: Radiance version: NREL 5.0.a.12 (by googs 2016.10.04) based on RADIANCE 5.0 Official Release by G. Ward
Info: Radiance binary dir: C:\openstudio-2.2.0\bin..\Radiance\bin
Info: Radiance library dir: C:\openstudio-2.2.0\bin..\Radiance\lib
Info: Running on Windows (sorry)
Info: Translating OpenStudio 2.x model to Radiance format...
Info: OpenStudio CLI version: 2.2.0.0a5e9cec3f
Failed.
