Hi, I get the following error after running a Radiance simulation with Open Studio 1.5.0 (Windows 8.1, Energy Plus v 8.1.0). I've already done "the Scan for Tools" and tried to reinstall Radiance on a shorter pat (C:/Radiance).
The job in 'C:/Users/marika/AppData/Local/Temp/OpenStudio.BP8728/resources/run/1-Ruby-0/in/model/radiance/gen_eplus/4-ModelToRad-0' did not finish successfully. ERROR: Cannot open file 'C:/Users/marika/AppData/Local/Temp/OpenStudio.BP8728/resources/run/1-Ruby-0/in/model/radiance/gen_eplus/4-ModelToRad-0/scene/Soggiorno/Pranzo_4_geom.rad' for writing Radiance export aborted. ERROR: Cannot open file 'C:/Users/marika/AppData/Local/Temp/OpenStudio.BP8728/resources/run/1-Ruby-0/in/model/radiance/gen_eplus/4-ModelToRad-0/scene/Ab1_-_Letto_N-O/N-E_geom.rad' for writing Radiance export aborted. ERROR: Cannot open file 'C:/Users/marika/AppData/Local/Temp/OpenStudio.BP8728/resources/run/1-Ruby-0/in/model/radiance/gen_eplus/4-ModelToRad-0/numeric/Ab1_-_Soggiorno/Pranzo_1.sns' for writing Radiance export aborted. ERROR: Cannot open file 'C:/Users/marika/AppData/Local/Temp/OpenStudio.BP8728/resources/run/1-Ruby-0/in/model/radiance/gen_eplus/4-ModelToRad-0/numeric/Ab1_-_Soggiorno/Pranzo_1.glr' for writing Radiance export aborted. ERROR: Cannot open file 'C:/Users/marika/AppData/Local/Temp/OpenStudio.BP8728/resources/run/1-Ruby-0/in/model/radiance/gen_eplus/4-ModelToRad-0/numeric/Ab1_-_Soggiorno/Pranzo_1.map' for writing Radiance export aborted. ERROR: Cannot open file 'C:/Users/marika/AppData/Local/Temp/OpenStudio.BP8728/resources/run/1-Ruby-0/in/model/radiance/gen_eplus/4-ModelToRad-0/scene/Ab1_-_Soggiorno/Pranzo_1_geom.rad' for writing Radiance export aborted. ERROR: Cannot open file 'C:/Users/marika/AppData/Local/Temp/OpenStudio.BP8728/resources/run/1-Ruby-0/in/model/radiance/gen_eplus/4-ModelToRad-0/scene/Ab1_-_Soggiorno/Pranzo_2_geom.rad' for writing Radiance export aborted. ERROR: Cannot open file 'C:/Users/marika/AppData/Local/Temp/OpenStudio.BP8728/resources/run/1-Ruby-0/in/model/radiance/gen_eplus/4-ModelToRad-0/scene/Soggirono/Pranzo_3_geom.rad' for writing Radiance export aborted. Adding path for local perl: C:/Program Files (x86)/OpenStudio 1.5.0/strawberry-perl-5.16.2.1-32bit-portable-reduced/perl/bin Setting RAYPATH: C:/Radiance/lib, C:/Radiance/bin, '.' Appending PATH: C:/Radiance/bin, '.' 2015-01-21 02:22:57 UTC: running 'ruby -I 'C:\Program Files (x86)\OpenStudio 1.5.0\Ruby' -I 'C:\Program Files (x86)\OpenStudio 1.5.0\ruby-install\ruby\lib\ruby\site_ruby\2.0.0' -I 'C:\Program Files (x86)\OpenStudio 1.5.0\ruby-install\ruby\lib\ruby\site_ruby\2.0.0\i386-msvcrt' -I 'C:\Program Files (x86)\OpenStudio 1.5.0\ruby-install\ruby\lib\ruby\site_ruby' -I 'C:\Program Files (x86)\OpenStudio 1.5.0\ruby-install\ruby\lib\ruby\vendor_ruby\2.0.0' -I 'C:\Program Files (x86)\OpenStudio 1.5.0\ruby-install\ruby\lib\ruby\vendor_ruby\2.0.0\i386-msvcrt' -I 'C:\Program Files (x86)\OpenStudio 1.5.0\ruby-install\ruby\lib\ruby\vendor_ruby' -I 'C:\Program Files (x86)\OpenStudio 1.5.0\ruby-install\ruby\lib\ruby\2.0.0' -I 'C:\Program Files (x86)\OpenStudio 1.5.0\ruby-install\ruby\lib\ruby\2.0.0\i386-mingw32' -I 'C:\Program Files (x86)\OpenStudio 1.5.0\Ruby\' -I 'C:\Program Files (x86)\OpenStudio 1.5.0\Ruby\openstudio' -I 'C:\Program Files (x86)\OpenStudio 1.5.0\Ruby\lib' '.\ModelToRad.rb' 'C:\Users\marika\AppData\Local\Temp\OpenStudio.BP8728\resources\run\1-Ruby-0\in.osm' ''' 2015-01-21 02:24:43 UTC: completed.
The stderr file reports:
*DL is deprecated, please use Fiddle
in.rb:211:in initialize': No such file or directory - C:/Users/marika/AppData/Local/Temp/OpenStudio.BP8728/resources/run/1-Ruby-0/in/model/radiance/options/daylightsim.opt (Errno::ENOENT)
from in.rb:211:inopen'
from in.rb:211:in `<main>'*
Any help is appreciated. Thanks in advance.
