I used a material from BCL and I want to change the thickness. Why does it not show up in the materials tab?
I downloaded "Steel-Framed - 6 in. Studs - 16 in. OC - R-21 Cavity Insulation" from BCL. I used it in a construction and I want to change its thickness. Why does it not appear in the materials tab?
