asked 7 years ago
Gio's avatar
Water condenser low temperature, chiller heat recovery
Hi, I'm trying to model a chiller with heat recovery, for DHW purposes.
I'm using a Chiller:Electric:EIR connected to a WaterHeater:Mixed. The model is running but I get a very low water temperature from the chiller condenser. Basically the water going into the tank water heater is decreasing its temperature since the inlet water temperature goes from 30°C to 20°C.
How can I get an higher temperature from the chiller condenser? have anyone had the same issue?
I found something here: https://unmethours.com/question/19434/heat-recovery-chiller-and-boiler-work-together/
Thank you in advance
How can I get an higher temperature from the chiller condenser? Did anyone have anyone had the same issue?
How can I get an higher temperature from the chiller condenser? Did anyone have the same issue?
