I have tried to run OS simulations with the following reporting measures, each of them crashing:
(1) Unmethours Troubleshooting Report with error messages as follows:
Applying UnmetLoadHoursTroubleshooting Result: Fail Error: invalid null reference Expected argument 1 of type std::string const &, but got NilClass nil in SWIG method "timeSeries" C:/Users/user1/AppData/Local/Temp/OpenStudioApp.ud5752/resources/measures/UnmetLoadHoursTroubleshooting/measure.rb:680:in "timeSeries" C:/Users/user1/AppData/Local/Temp/OpenStudioApp.ud5752/resources/measures/UnmetLoadHoursTroubleshooting/measure.rb:680:in "getTimeSeries" C:/Users/user1/AppData/Local/Temp/OpenStudioApp.ud5752/resources/measures/UnmetLoadHoursTroubleshooting/measure.rb:577:in "initZoneMetrics" C:/Users/user1/AppData/Local/Temp/OpenStudioApp.ud5752/resources/measures/UnmetLoadHoursTroubleshooting/measure.rb:496:in "block in run" C:/Users/user1/AppData/Local/Temp/OpenStudioApp.ud5752/resources/measures/UnmetLoadHoursTroubleshooting/measure.rb:494:in "each" C:/Users/user1/AppData/Local/Temp/OpenStudioApp.ud5752/resources/measures/UnmetLoadHoursTroubleshooting/measure.rb:494:in "run" :/ruby/2.2.0/gems/openstudio-workflow-1.2.1/lib/openstudio/workflow/util/measure.rb:441:in "apply_measure" :/ruby/2.2.0/gems/openstudio-workflow-1.2.1/lib/openstudio/workflow/util/measure.rb:67:in "block in apply_measures" :/ruby/2.2.0/gems/openstudio-workflow-1.2.1/lib/openstudio/workflow/util/measure.rb:31:in "each_index" :/ruby/2.2.0/gems/openstudio-workflow-1.2.1/lib/openstudio/workflow/util/measure.rb:31:in "apply_measures" :/ruby/2.2.0/gems/openstudio-workflow-1.2.1/lib/openstudio/workflow/jobs/run_reporting_measures.rb:81:in "perform" :/ruby/2.2.0/gems/openstudio-workflow-1.2.1/lib/openstudio/workflow/run.rb:256:in "step" :/ruby/2.2.0/gems/openstudio-workflow-1.2.1/lib/openstudio/workflow/run.rb:210:in "run" :/openstudio_cli.rb:802:in "execute" :/openstudio_cli.rb:620:in "execute" :/openstudio_cli.rb:1515:in "<main>" eval:85:in "eval" eval:85:in "require_embedded_absolute" eval:70:in "block in require" eval:64:in "each" eval:64:in "require" eval:2:in "<main>" Failed.
Similarly (2) Ventilation Report with error messages as follows:
Applying VentilationQAQC Result: Fail Error: invalid null reference Expected argument 1 of type std::string const &, but got NilClass nil in SWIG method "timeSeries" C:/Users/user1/AppData/Local/Temp/OpenStudioApp.ud5752/resources/measures/VentilationQAQC 1/measure.rb:342:in "timeSeries" ......
What can be done ?
