Hello.
I studid heat balance in energyplus. I want to know heat balance between wall inside surface and zone. (The Zone, no HVAC)
In Engineering reference, eqation is
qlwx+qsw+qlws+qki+qsol+qconv =0
but, when I add all, I can't get a Zero.
Surface inside face net surfaced thermal radiation heat gain rate per area + Surface inside face solar radiation heat gain rate per area + Surface inside face lights radiation heat gain rate per area + Surface inside face internal gains radiation heat gain rate per area + Surface inside face system radiation heat gain rate per area + Surface inside face convection heat gain rate per area + surface average face conduction heat gain rate per area
Why..?
