I would like to run a building simulation where I can actively tweak parameters of the HVAC and lighting systems (e.g. the thermostat set points) while the simulation is running. For example, I would like to run the simulation for an hour, get access to the current meter readings, then change some parameters, then continue the simulation from where it left off with the new parameters. In looking into Energy Plus, it seems like the shortest simulation I can run is for a full day, and it's not clear to me how to set initial values for meter readings. If I could run an hourly simulation and set some initial values then I think Energy Plus could work.
Is this possible using Energy Plus or eQUEST? If not, is there another simulation system which would support this?
Thank you!
