In PAT 2.1 on the Design Alternatives tab you can assign each alternative a Name that the software then appears to assign a Datapoint ID to for storing results - how can I keep track of which Datapoint ID is mapped to each Design Alternative Name?
The Datapoint IDs are long alphanumeric strings (like ebb2458a-bda2-483d-a295-e3f9d8a7926c); when browsing through the results directory (in localResults) there will be a folder named with the Datapoint ID for each alternative - other then referring back to the PAT Design Alternatives tab and looking up which Datapoint ID goes with each Name is there an easier way to track which results directory is for which alternative?
