I have a system that comprises 4 air-sourced heat pumps for both space heating and cooling. I saw the new integrated heat pump coil system can model a single air-sourced heat pump so it cannot provide both heating and cooling simultaneously.
Is it possible to connect the integrated heat pumps in parallel so that the plant can supply both hot water and chilled water?
Or must I stay with 4 air-cooled chiller + 4 Coil:WaterHeating:AirToWaterHeatPump in order to achieve that?
