Hello,
I am a new user of Modelica, so the answer to my question might be obvious to you. It's the first time that I am using this forum as well.
I am looking the BESTEST Case 600 model and specifically the component Modelica.Blocks.Sources.CombiTimeTable. In this model, the setpoint temperature for heating or cooling is been set manual, by using a static setpoint. I am interested in including a variable as input for the setpoint temperature, so, for instance, having different setpoint for every month/day/hour. However, when I am using a variable, T_com, as an input, I am getting the error below: "The variability of the definition equation: combiTimeTable.table = T_com; is higher than the declared variability of the ". When I am changing the input to a parameter my model is working. Could you please advice me how to solve this issue?
Thank you in advance.
Charalampos
