Hello everyone!
I´m learning Openstudio step and step, finally I reach the simulation results about "HVAC loads", unfortunately a question appeared, and I wondered if someone could solve.
The Sum of monthly HVAC load profiles is different to the sum of zone Zone Air System Sensible Cooling Rate, It would be the same.
I´m using a Cooling district in order to discover the cooling demand. Maybe the different is the latent load, if it is true, which value should I reach, because I have used "Zone Total Internal Latent Gain Rate" and all values are 0.
Thank you very much! And have a good day!
