Hello,
Is it possible to use performance coefficient generated by PG&E Cool Tools Chiller tool can be used as an input in E+? It is my understanding that the chiller curve data are dimensionless ratios, so the curve-fits should work regardless of units-system. The raw data would be different, but the curve coefficients should be identical.Is it so??
Please help!
regards,
