With FMI, is it possible to output energy values at the end of each simulation timestep in energyplus, and use python code to change the EMS code for the next timestep?
I need to call python code from energyplus software and the python code should be able to access my EMS for the next timestep. Keeping the python modules of theano, keras and numpy intact. Is this possible ? If yes, can you please suggest some documentation where I can start this ?
