Hi,everyone,I want to konw how can I set the "Tolerance temperature" in E+ which is the temperature control. The situation can be describe that I want to use AC when the room temperature is higer than 29 ℃,but if I use AC the cooling setpoint is 26 ℃. So which temperature should I fill in HVAC Templates:Themostat:Constant Cooling Setpoint ? And if I can set the two schedule to meet the situation that when the room temperature lower than 29 ℃ I close the AC although the operation schedule is on.
