Hello everybody,
When I use Foundation boundary condition for the slab I can't get Surface Outside Face variables which is very understandable. However, is there anyway to be able to measure the temperature within the slab. Although I am using the CFD algorithm the nodes that is created inside the floor surface will not have any result I assume that is related to the fact that Foundation:Kiva does not use the same algorithm as the rest of the model.
Thank you,
