Hi all,
It's already a knowing Problem, which was already posted some days ago...but there was no clear answer on it.. I have just the same Problem when running Openstudio1.5 with Radiance coupling: following Errors occure in the very beginning of the Simulation..
no sql file given, running EnergyPlus... Adding path for local perl: C:/Program Files (x86)/OpenStudio 1.5.0/strawberry-perl-5.16.2.1-32bit-portable-reduced/perl/bin Setting RAYPATH: C:/Radiance/lib, C:/Radiance/bin, '.' Appending PATH: C:/Radiance/bin, '.' 2015-01-15 16:18:02 UTC: running 'ruby -I 'C:\Program Files (x86)\OpenStudio 1.5.0\Ruby' -I 'C:\Program Files (x86)\OpenStudio 1.5.0\ruby-install\ruby\lib\ruby\site_ruby\2.0.0' -I 'C:\Program Files (x86)\OpenStudio 1.5.0\ruby-install\ruby\lib\ruby\site_ruby\2.0.0\i386-msvcrt' -I 'C:\Program Files (x86)\OpenStudio 1.5.0\ruby-install\ruby\lib\ruby\site_ruby' -I 'C:\Program Files (x86)\OpenStudio 1.5.0\ruby-install\ruby\lib\ruby\vendor_ruby\2.0.0' -I 'C:\Program Files (x86)\OpenStudio 1.5.0\ruby-install\ruby\lib\ruby\vendor_ruby\2.0.0\i386-msvcrt' -I 'C:\Program Files (x86)\OpenStudio 1.5.0\ruby-install\ruby\lib\ruby\vendor_ruby' -I 'C:\Program Files (x86)\OpenStudio 1.5.0\ruby-install\ruby\lib\ruby\2.0.0' -I 'C:\Program Files (x86)\OpenStudio 1.5.0\ruby-install\ruby\lib\ruby\2.0.0\i386-mingw32' -I 'C:\Program Files (x86)\OpenStudio 1.5.0\Ruby\' -I 'C:\Program Files (x86)\OpenStudio 1.5.0\Ruby\openstudio' -I 'C:\Program Files (x86)\OpenStudio 1.5.0\Ruby\lib' '.\ModelToRad.rb' 'C:\Users\c8461098\AppData\Local\Temp\OpenStudio.Sv6408\resources\run\1-Ruby-0\in.osm' ''' 2015-01-15 16:18:04 UTC: completed. failed to run ModelToRad
So it seems, that everythink is allright the Radiance Installation and the PATHs. I have installed the actual Version 4.2.2 directly on C:\Radiance. There is still this Problem to run the ruby-script "ModelToRun"...can there be anything wrong with this file..?
Thanks!
