Designing 'Betweenglassblind' Issue
While designing shaded construction for 'betweenglassblind' I am getting following error. I have followed all the steps for designing multi-layered window constructions. Still, couldn't manage to run my model. Please help!
** Severe ** CheckAndSetConstructionProperties: Error in window construction ARTLIGHT WINDOW SHADED-- ** ~~~ ** For multi-layer window constructions the following rules apply: ** ~~~ ** --The first and last layer must be a solid layer (glass or shade/screen/blind), ** ~~~ ** --Adjacent glass layers must be separated by one and only one gas layer, ** ~~~ ** --Adjacent layers must not be of the same type, ** ~~~ ** --Only one shade/screen/blind layer is allowed, ** ~~~ ** --An exterior shade/screen/blind must be the first layer, ** ~~~ ** --An interior shade/blind must be the last layer, ** ~~~ ** --An interior screen is not allowed, ** ~~~ ** --For an exterior shade/screen/blind or interior shade/blind, there should not be a gas layer ** ~~~ ** ----between the shade/screen/blind and adjacent glass, ** ~~~ ** --A between-glass screen is not allowed, ** ~~~ ** --A between-glass shade/blind is allowed only for double and triple glazing, ** ~~~ ** --A between-glass shade/blind must have adjacent gas layers of the same type and width, ** ~~~ ** --For triple glazing the between-glass shade/blind must be between the two inner glass layers, ** ~~~ ** --The slat width of a between-glass blind must be less than the sum of the widths ** ~~~ ** ----of the gas layers adjacent to the blind. ** Severe ** WindowProperty:ShadingControl="SHADING CONTROL 1" the Construction with Shading Name="ARTLIGHT WINDOW SHADED" ** ~~~ ** of Shading Type="BETWEENGLASSBLIND" should have two or three glass layers and a ** ~~~ ** between-glass blind layer with a gas layer on each side. ** Fatal ** GetSurfaceData: Errors discovered, program terminates.
