I am having a problem getting the LSAT setup on my personal machine. I have complete the instructions for installation as found here, but when I go to run "rake clean" or "bundle exec rake run" it gives me the message " OpenStudio did not load, but most functionality still available.
When I continue with bundle exec rake run, I am able to select an analysis, and I select the example analysis "SEB_Calibration_Rgenoud_2013". The command line then says starting up cluster, sometimes never actually starts the analysis. The last output that I get from the CLI is Server SSH Command:
ssh -i C:/AWS/OpenStudio-a ....
I can see on the AWS console that the servers that I called up have completed their checks, but when I try and go to the address of the server, it says that the page is not available.
Any ideas what could be wrong? Thanks in advance for the help!
