Hi!
I set operation schedule specifying when air side economizer is available and set the schedule to the Field: Time of Day Economizer Control Schedule Name
However, checking at the result Air System Outdoor Air Economizer Status, air side economizer is operating even when it is specified 0(disable this feature).
I suspect that some other parameter has priority to this schedule but could not find any description in the document.
Does anyone know what is causing this situation?
Thank you.
