I was wondering whether anyone could tell me what the following error message means. It shows up when running the Radiance Daylighting Measure.
Based on the Sub Surfaces tab in the Spaces tab of OpenStudio, Sub Surfaces 6,8 and 10 are all three opaque doors and tagged as "Door", not as "Window". So why is this complaining about "Fenestration"?
Also, when I remove the Radiance Daylighting Measure, this seems to run through just fine. It even reports "Updating Daylighting Coefficients (Map Points)". Does this mean it is running Radiance anyway, or is it running the EnergyPlus Daylighting engine instead? I have OpenStudio Version 1.14.
