Hi , I'm using Openstudio 2.1 ,I've applied OpenStudio Result to reporting measures , when I run the simulation I get the following error with no result. Failed: IP units were provided, SI units were expected. Leave EnergyPlus tabular results in SI units to run this report.
I need both Energy plus and OpenStudio reports to get End uses and monthly utility rate.Thanks.
