Create DOE Prototype Building measure run in CLI
I modify the compact.osw (shown in Figure) of the example in OpenStudio 2.1, and put the measure, "Create DOE Prototype Building" into the folder ("measure"). When I run CLI according to the instruction, I cannot get the results of simulation. Do I do the work incorrect? Could someone provide me a case that can be successful to modify the model into other prototype building models?
The error is pasted below:
Error: 419: unexpected token at '{
"measure_dir_name": "CreateDOEPrototypeBuilding",
"arguments": {
"building_type": 'SmallOffice',
"template_chs": '90.1-2004',
"climate_zone": 'ASHRAE 169-2006-5A'
Backtrace:
:/ruby/2.2.0/json/common.rb:155:in parse'
:/ruby/2.2.0/json/common.rb:155:inparse'
:/ruby/2.2.0/gems/openstudio-workflow-1.2.1/lib/openstudio/workflow/adapters/input/local.rb:32:in initialize'
:/ruby/2.2.0/gems/openstudio-workflow-1.2.1/lib/openstudio/workflow/run.rb:119:innew'
:/ruby/2.2.0/gems/openstudio-workflow-1.2.1/lib/openstudio/workflow/run.rb:119:in initialize'
:/openstudio_cli.rb:799:innew'
:/openstudio_cli.rb:799:in execute'
:/openstudio_cli.rb:620:inexecute'
:/openstudio_cli.rb:1515:in <main>'
eval:85:ineval'
eval:85:in require_embedded_absolute'
eval:70:inblock in require'
eval:64:in each'
eval:64:inrequire'
eval:2:in `<main>'
Exception: 419: unexpected token at '{
"arguments": {
<main>: unexpected return
