Dear all In the fogging device (type 507a) of trnsys, with the outlet air RH humidity controlled, the default value of relative humidity set point is 95. I need a 100% relative humidity for the outlet air. Is it possible to have 100% relative humidity for the outlet air, in practice? Thank you
