is a fogging device able to produce fully saturated air at the outlet? If not, what is the maximum possible relative humidity ?
| 1 | initial version |
I'm going to use a foggig device in an air handling unit to produce humid air for a greenhouse. is a fogging device able to produce fully saturated air at the outlet? If not, what is the maximum possible relative humidity ?
| 3 | retagged |
| 4 | retagged |
| 5 | retagged |
| 6 | retagged |
