Hi all,
I am studying the effect of altering the insulation performance(u-value) of walls and windows that are directly exposed to ambient air in buildings with high internal temperatures. I use Energy Plus together with design builders.
So other walls (inner wall, ceiling, floor) except the outer wall are setting adiabatic . Because it is only to see change of outer wall.
And I select the output in E+: "Surface average face conduction heat transfer rate"
I think, other walls have to have a value of zero except for the outer wall, but it's not. They all have value. Why?
In addition, when the U-value of the outer wall is enhanced, ( I mean that the wall's u-value 0.5 -> 0.2) Outer wall's "Surface inside face convection heat gain rate" value decreased, and other walls values are increased. Why?
please answer about my question.
Thank you.
