I have tried to make a new weather file with weather collected data at Elements, but when I do it with a "new file" and paste dry bulb Temp. or Relative Humidity the cells get blank (with no data) while on radiation data, it let me paste the data. I tried then to do it changing an existing Weather file and I succeded with dry bulb Temp. and relative humidity, but there are other data that cannot be changed (Azimut, solar angle,...). I deleted and installed the program several times, in case there where intallation problems, but didn´t succeed. Can you help me?
