In AirLoopHVAC:UnitarySystem it appears possible to set a/the Control Method to a Controlling Zone. I've run through the documentation, but I havent come across a means to do this with any other AirLoopHVAC objects. Is this single zone control-ability unique to the UnitarySystem?
If I understand this properly, the control zone will control the Main Heat/Cooling/Dehminidification/fan, and any other zones will ride along....yes? I can also add the OA objects need, per [this question] https://unmethours.com/question/9882/oa-for-unitary-system/
Am I missing something here? Is there some other SingleZone w/ slave zone type options/objects/configurations? This approach may work for now, but my 'real' system system order is different than the Unitary. Thanks.
