I just installed OS 2.0.5. When I opened SketchUp I checked the box to install the plugin and got the following error messages:
Error Loading File openstudio.rb
Error: #<loaderror: cannot="" load="" such="" file="" --="" c:="" users="" david="" appdata="" roaming="" sketchup="" sketchup="" 2016="" sketchup="" plugins="" openstudio.so="">
C:/Users/David/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/openstudio.rb:55:in require_relative'
C:/Users/David/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/openstudio.rb:55:in<top (required)>'="" error="" loading="" file="" openstudio.rb="" error:="" #<loaderror:="" cannot="" load="" such="" file="" --="" c:="" users="" david="" appdata="" roaming="" sketchup="" sketchup="" 2016="" sketchup="" plugins="" openstudio.so="">
C:/Users/David/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/OpenStudio.rb:55:in `require_relative'
C:/Users/David/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/OpenStudio.rb:55:in `<top (required)>'<="" h2="">
I tried manually copying openstudio.so to my plugins folder but got the same or similar messages. I had no problems with the earlier version I had installed (1.14.?). OpenStudio is installed in my Program Files folder in a folder I created (the default is to install it in the top C drive director). Any idea how to fix this?- Thanks!
