I'm encountering the following error after trying to use the create baseline building measure:
<errors> <logmessage> <channel>openstudio.ruleset.Create Baseline Building</channel> <message>Model has been assigned a weather file, but the file is not in the specified location of 'files/JPN_TOKYO_476620_IW2.EPW'.</message> </logmessage> </errors>
I've updated Open Studio for the 1.14 version, I've moved the weather file to the "Default Weather Location" directory listed under scan for tools, but the error was not solved.
