I download the model of supermarket from DOE's Commercial Reference Building Models, and transfer it into the version-8.6 EnergyPlus model. However, when I import the IDF file into OpenStudio 1.14.0 and 2.0, it says that some portions of the idf file were not imported (Only geometry, constructions, loads, thermal zones, and schedules are supported by the OpenStudio IDF import feature). Does it mean that OpenStudio is unable to load EnergyPlus files created by DOE? And are there some solutions to solve this problem? Thanks.
