I am trying to import my Glazing properties from WINDOW into OS 1.14.0, by generating an idf and importing it into OS. When I do this, my Spectral data set doesn't forward translate to idf, similar to this issue. The 'Window Glass Spectral Data Set Name' is blank(
The issue mentioned above in Github asks the same question, and identifies that the MaterialProperty:GlazingSpectralData is not wrapped in OS. But it seems to have been marked as a milestone for OS 1.14 and closed, so I was wondering if this has been fixed? If not, do I have to write an Eplus script to read this object from the idf? Thanks,
