Hi,
I am running a parametric analysis using prototypes that are autosizing most HVAC components. How can I run this prototype once, to obtain the values auto-calculated, and then fix those values for subsequent runs. I do not want each run to autosize the HVAC system, but to use only the autosized values from the 1st run.
Thank you!
