When I try to run BCVTB with EnergyPlus, programme terminates and gives the following errors :
* Severe * Output:PreprocessorMessage="EPMacro" has the following Severe conditions: * ~~~ * at approximately input line number=5201: column=10 * ~~~ * undefined macro name referenced * ~~~ * symbol=Insulation * ~~~ * refer to <file>.epmdet for details.
* Severe * Output:PreprocessorMessage="EPMacro" has the following Severe conditions: * ~~~ * at approximately input line number=5210: column=17 * ~~~ * undefined macro name referenced * ~~~ * symbol=Glass * ~~~ * refer to <file>.epmdet for details.
* Severe * GetBranchInput: Branch="PACKAGED ROOFTOP HEAT PUMP MAIN BRANCH", invalid data. * ~~~ * ..Invalid Pressure Drop Curve Name="AIRLOOPHVAC:OUTDOORAIRSYSTEM". * ~~~ * This curve could not be found in the input deck. Ensure that this curve has been entered * ~~~ * as either a Curve:Functional:PressureDrop or one of Curve:{Linear,Quadratic,Cubic,Exponent} * ~~~ * This error could be caused by a misspelled curve name
* Severe * During Branch Input, Invalid Component Type input=AIR LOOP HVAC OUTDOOR AIR SYSTEM 2 * ~~~ * Component name=NODE 82 * ~~~ * Occurs on Branch=PACKAGED ROOFTOP HEAT PUMP MAIN BRANCH
* Severe * During Branch Input, Invalid Component Type input=NODE 89 * ~~~ * Component name=NODE 90 * ~~~ * Occurs on Branch=PACKAGED ROOFTOP HEAT PUMP MAIN BRANCH * Severe * During Branch Input, Invalid Component Type input=NODE 91 * ~~~ * Component name=FAN:CONSTANTVOLUME * ~~~ * Occurs on Branch=PACKAGED ROOFTOP HEAT PUMP MAIN BRANCH
* Severe * GetBranchInput: Invalid Branch Input, preceding condition(s) will likely cause termination.
* Severe * ExternalInterface:Schedule Name, duplicate name=OFFICEHTGPOINT
* Severe * ExternalInterface:Schedule Name, duplicate name=OFFICECLGPOINT
* Fatal * ProcessScheduleInput: Preceding Errors cause termination.
