Is there a script, a measure, or a trick to quickly removing HVAC equipment from a model? I tried removing it through text editing the OSM but it caused an error in OS.
I'm working on a mulitfamily building with 161 dwelling units and about 100 dwelling unit thermal zones. For my baseline I've added the PTHP directly to Zone Equipment rather than using an air loop. To delete all of them I went through and clicked each and hit the X button to delete it, but that was very time consuming as there was about a 2 second pause between each click while the PC worked on it. Any tips on a quicker way to do this in the future?
Is there a way to copy the PTHP (or other equipment) in the library? I'd like to create some of my own equipment templates.
