Hi!
Simulation failed without showing any error message.
I know that we can check the error message in osm file name folder > run > 6-EnergyPlus-0 > eplusout.err referring to previous post
However, only 3 folder is created in the run folder in my case(0-Null, 1-UserScript-0, 2-ModelToIdf-0). Thus I cannot check above mentioned file.
Does anyone know why I am getting this error and which file should I check to fix the problem?
