I recently converted to OpenStudio 1.14 and can no longer run the "Set Output Table to IP Units" measure. Can someone help me modify the script to run with this version? Also, is there a way to get the OpenStudio output report and the EnergyPlus report in IP units? I am often running two separate simulations just to get the output reports I need. Thanks in advance!
