As a follow up of this (https://unmethours.com/question/23088/unable-to-find-openstudio-shading-control-setpoint/) I created an OpenStudio measure to change the ShadingControlType to one of the "unsupported" values like OnIfHighZoneAirTemperature.
The measure let me choose out of the existing ShadingControlobjects, a new ShadingControlType (String) and a new setpoint.
The measure basically works when I choose a supported control type, but I can not choose one of the unsupported values. OpenStudio always resets this to OnIfHighSolarOnWindows.
Is there an implicit input validation in the OpenStudio sources?
I had a look at ShadingControl.cpp, but could not find such validation code.
As a side question:
What does this line of code in setShadingControlType do?
bool result = setString(OS_ShadingControlFields::ShadingControlType, shadingControlType);
I can not find the OS_ShadingControlFields definition in the source files.
Should I go for a EnergyPlus measure to change the control type strategy?
I can share my measure if it would be helpful.
