The Sketchup Make 2016 is not available for download for the Openstudio plugin. However, Openstudio 1.14.0 allows only plugins from Sketchup 2016 to be compatible to work with. Even if Sketchup 2017 is downloaded, Openstudio prompts for sketchup 2016 in order to complete installing, successfully. And I'm unable to sync the features of sketchup 2017 with openstudio while working on it. The openstudio only recognizes 2016 version of sketchup, which is no more available. Can you please suggest a solution ?
